Tezina PSA Motora (i mjenjaca) - lista
kljuc13
Postovi: 523
Lokacija: Bihac
Vozim: (T1000)
Motor: 1.6 HDi 80KW
Ima zahvala: 97 puta
Post Postao/la kljuc13 »
Listajuci par foruma i dokumenata naletio sam na spisak "suhe" tezine "popularnih" PSA motora pa sam htio da podijelim za druge kojima bi mozda ove informacije bile od koristi za projekte ili sl. Usput sam dodao i mjenjace zajedno sa brojkama do koliko Nm mogu podnijeti prije nego se raspu kao necija ekonomija :84: .
TU9M (954cc 8v alloy block monopoint injection) = 89kg
TU1M (1124cc 8v alloy block monopoint injection) = 90kg
TU3M (1360cc 8v alloy block monopoint injection) = 92kg
TU3FJ2 (1360cc 8v iron block injection) = 113kg
TU5JP (1587cc 8v iron block injection) = 109kg
TU5J4 (1587cc 16v iron block injection) = 117kg
TUD5 (1527cc 8v diesel) = 126kg
XU52C (1580cc 8v alloy block carb) = 107kg
XU5JP (1580cc 8v alloy block injection) = 108.5kg
XU7JP (1761cc 8v alloy block injection) = 114kg
XU7JP4 (1761cc 16v alloy block injection) = 125kg
XU92C (1905cc 8v alloy block carb) = 115kg
XU102C (1998cc 8v iron block carb) = 132kg
XU10J2C (1998cc 8v iron block injection) = 140kg
XU10J2TE (1998cc 8v iron block turbo) = 149kg
XU10J4 (1998v 16v iron block injection aka "S16") = 160kg
XU10J4TE (1998cc 16v iron block turbo aka "405 T16") = 165kg
XU10J4R (1998cc 16v iron block injection) = 143kg
XU10J4RS (1998cc 16v iron block injection "GTi-6") = 143kg
XUD7TE (1769xx 8v diesel) = 150kg
XUD9TE (1905cc 8v diesel) = 140kg
XUD11ATE (2088cc 12v diesel) = 171kg
DW10TD (1997cc 8v diesel) = 150kg
DW12TED4 (2179cc 16v diesel) = 182kg
EW7J4 (1749cc 16v alloy block injection) = 137.5kg
EW10J4 (1997cc 16v alloy block "206 GTi") - 137kg
EW12J4 (2230cc 16v alloy block injection) = 153kg
ES9J4 (2946cc 24v V6 alloy block) = 215kg
ES9J4S (2946cc 24v V6 alloy block) = 215kg
Manuelni mjenjaci
MA (do 138Nm) = 31.7kg
BE (izmedju 210 i 250Nm) = 36.6kg
ML (izmedju 300 i 350Nm) = 45 - 49.3kg
Automatik mjenjaci
AL4 (do 200Nm) = 70kg
4HP20 (do 330Nm) = 88kg
Ovi su korisnici zahvalili autoru kljuc13 za post (ukupno 3):
milos_jecdusankole_kolak
Natrag na “Motor”
