Resetovanje BSI -a
Re: Resetovanje BSI -a
A evo i tekstualno , samo prevedite sebi :)
Peugeot BSi reboot procedure
Some of you will have already come across a strange problem when programming
keys on 2002 onwards Bsi equipped Peugeot. This usually presents
itself as a complete instrument cluster failure after the keys have
been programmed when the customer comes to collect the car.
BSI Unit
The BSI unit is basically a computer which
handles a multitude of functions such as
odometer value, central locking, lights and
immobiliser. Some later Bsi units are liable
to corrupt their own software program if
not “woken up” in a specific way after
programming keys or battery disconnection.
The details of this are explored
thoroughly in a Peugeot TSB but I will
summarise for you briefly.
Procedure for Initialising the BSI after key learning
1. Disconnect the diagnostic tool.
2. Put the driver’s window down, lift the bonnet and ensure all
equipment is switched off.
3. Ensure all doors are closed and remove key from the
ignition.
4. Wait for 3 minutes, disconnect the vehicle battery and wait
15 seconds.
5. Reconnect the vehicle battery, wait a further 10 seconds (do
not open doors.)
6. Switch on the side lights through the driver's window.
7. Switch on the ignition and check system’s functionality.
8. Hold lock button on key down for 10 seconds.
9.remove key open & close door test central locking system
10. Start the engine and complete the system’s check.
Failure to follow this procedure could result in incorrect operation of many
BSI related items.
It did take three attempts following this procedure before it worked.
This is a shorter version of the TSB given to me regarding battery dis-connects on Peugeot Citroen BSi units:
PROCEDURE FOR BATTERY DIS-CONNECTION (The 3 Minute Rule)
Whenever a vehicle battery has to be dis-connected, switch off all equipment, interior lights etc, close the doors leaving the drivers window open.
Switch off the ignition and remove the key and any DIAG equipment.
Wait a full 3 minutes before disconnecting the battery.
The BSi must be allowed to go to SLEEP ie into "power save mode". Do not operate any equipment on the vehicle during this time. Remember, even opening the bonnet will wake the BSi on a vehicle fitted with alarm.
If the battery is under the bonnet, open the bonnet first and leave it up. 807 batteries can be dis-connected through the drivers window, remove floor cover first.
ALWAYS disconnect any DIAG equipment and do not operate any plips from other vehicles during the 3 minute waiting period.
PROCEDURE FOR BATTERY RECONNECTION
Unless otherwise instructed by Peugeot or Product Service, you must always carry out the following procedure, often referred to as a "soft re-boot", to minimise the possibility of the BSi corrupting its own software when reconnecting the vehicles battery supply.
Ensure the procedure for battery disconnection has been adhered to and importantly all BSi functions were switched off with the drivers window left down.
1 Close all doors
2 Remove ignition key if left in ignition
3 Reconnect battery. DO NOT open any doors
4 Wait 10 seconds
5 Switch on healights through the drivers window (you will hear a "bong")
6 Switch on ignition then start the vehicle and check system functions
NOTE: Upon reconnection, if any vehicle function controlled by the BSi i.e . interior light is switched on,the internal operation of the BSi has the potential to spike or corrupt its configuration and software program......
BSI Unit
ignition.
15 seconds.
not open doors.)
BSI related items.
1 Close all doors
4 Wait 10 seconds
- srky_ug
- Postovi: 561
- Lokacija: Ugljevik
- Ima zahvala: 1 put
Ako ko moze malo pojasniti ove tri stavke nisam bas siguran da sam ih skontao najbolje , hvala :)
- Phantom
- Postovi: 2613
- Lokacija: Teslic
- pohvaljen: 91 put
Dodas kontakt, i drzis dugme za zakljucavanje 10 sekundi (kontam ono pored 4 zmigavca) izvadi kljuc, otvori i zatvori vrata i testiraj centralno zakljucavanje :)
To radis ako radis inicijalizaciju kljuca,tj daljinsko zakljucavanje i otkljucavanje
ne to dugme vec na kljucu za daljinskoPhantom je napisao/la:Dodas kontakt, i drzis dugme za zakljucavanje 10 sekundi (kontam ono pored 4 zmigavca) izvadi kljuc, otvori i zatvori vrata i testiraj centralno zakljucavanje :)srky_ug je napisao/la:7. Switch on the ignition and check system’s functionality.
- srky_ug
- Postovi: 561
Isprobao sam sve moguce ,sto ste objasnjavali o resetovanju ali kod mene nece pa nece , nema onog bing kad upalim svijetla ,cekao sam cak i duze malo kad sam skinuo klemu pa mi je i player resetovao i board ali nece ono sa svijetlima da se cuje , ne znam sta mu je :S
Ja sam ovo uradio kad sam mjenjao akumulator jer nisam znao upaliti auto
al nesto ne znam da sam ista 'dobio' resetovanjem.
- Phantom
- Postovi: 2613
- Lokacija: Teslic
- pohvaljen: 91 put
Evo meni hoce BING :)srky_ug je napisao/la:Isprobao sam sve moguce ,sto ste objasnjavali o resetovanju ali kod mene nece pa nece , nema onog bing kad upalim svijetla ,cekao sam cak i duze malo kad sam skinuo klemu pa mi je i player resetovao i board ali nece ono sa svijetlima da se cuje , ne znam sta mu je :S
1. Upalis auto ugasis potrosace
2. Spustis vozaces prozor i otvoris haubu
3. Sacekaj 3 min
4. Skinuti klemu
5. Sacekaj 5 min i vrati klemu
6. Upali svjetla kroz prozor vozacev
7. Upali auto
Eto tako sam ja i resetovao sam
- Phantom
- Postovi: 2613
- Lokacija: Teslic
- pohvaljen: 91 put
ma Srky-a nam ne slusa BING nesto :)
Meni je iz prve uspjelo, e sad dali ce biti kakvih promijena vidjecemo :)
Ja nekad tamo u novembru-decembru mijenjao akumulator. I ja mislio to je sad klasika.. skini, stavi drugi, gotovo.. ja za kljuc, auto vergla, nece da sastavi.. i cuje se taj neki glupi zvuk BING. Okreni obrni nece pa nece.. :) Iznerviram se, na net i guglam ''zamjena akumulatora na P-307''
Nadjem kako ide 'postupak' zamjene akumulatora, odradim ovako, upali auto odmah i tek nakon mjesec-dva sam saznao da sam tim postupkom resetovao BSI
- srky_ug
- Postovi: 561
Sve sam ja to tako sinoc odradio ali nista se ne desava kad okrenem rucicu,tj ne cuje se nista , jednostavno se samo svijetla upale i to je to ... mozda nesto ne radim kako treba ali ne vjerujem sve po redu idem ...
- Небојша.Гогић
- Postovi: 27
- Pridružen/a: 25. sij 2017, 18:55
- Lokacija: Sremski Karlovci
- Vozim: Peugeot 206 1.1
Ako moze neko na laksi nacin da objasni ovaj postupak reseta bio bih jako zahvalan(neide mi ovo prevodjenje engkeskog jezika jebiga). Auto pug 206 1.1 '99.god obicna centrala kljuc nema daljinsko
